dirte
Dec 29, 2022Aspirant
CAx30 modem not broadcasting wifi
My AX2700 was working fine until rolling power outages a few days ago. Internet never came back up and I tried several restarts. As a last resort I plugged in an old Netgear modem and router and thos...
Kitsap
Dec 29, 2022Master
FURRYe38 wrote:Try pressing the Reset button in back for 10 seconds then release and walk thru the setup wizrard. Let us know if this gets the wifi radios going.
Be aware the reset button wipes out all of your settings and you have to reconfigure the device from scratch. Thus the need to walk through the setup wizard.
The reset button will not change the state of the external Wi-Fi radio on/off button.
dirte
The comcast tech also completed a factory reset so I believe that step is accounted for without any change in the wifi availability.
Current Status: Xfinity --> AX2700 then it breaks there and no wireless network comes up despite solid lights on the modem/router.
Thanks guys
- KitsapDec 29, 2022Master
dirte wrote:The comcast tech also completed a factory reset so I believe that step is accounted for without any change in the wifi availability.
Thanks guys
Believing some thing is done and knowing it is done are two different things. I find it very difficult to believe a Comcast service technician would perform a firmware default reset on a customer owned gateway. In particular when the action is simple for the gateway owner to perform and know for certain it is done. Suggest you download the owners manual and see page 80 for the instructions before you throw the device in the recycle bin.
- FURRYe38Dec 29, 2022Guru - Experienced User
I would do the factory reset your self to be sure the modem is being reset by you. Pressing the reset button 10-15 seconds will or should reset the modem and this will also change the wireless button and radios to be enabled by default.
IF this fails to bring back the wifi radios, possible the modem is faulty and needs to be RMAd. Something to contact NG about and see.
Last resort you might try a 30-30-30 reset...won't hurt to try.
Thanks guys
