Izterico
Dec 05, 2022Follower
CAX30 modem not recognizing upgraded speeds from XFINITY
Upgraded my plan this weekend 800 mbps and I am still seeing 60 megs down and 6 up. Looked for a Qos setting on the CAX30 modem/router, restarted, reset, and have been on the phone with multiple xfin...
Dec 05, 2022Guru - Experienced User
Are you testing wired or wireless speeds? 60mbps is pretty standard over 2.4ghz but you should get faster wired.
what wired speeds do you get?
Did you factory reset it after the upgrade?
