JOHNJONESNOVELS
Dec 27, 2021Follower
CAX30 Modem/Router - Can switch OUT of Access Anywhere
Looking for help with the Access Anywhere connection. Picked up a new AX6/Model CAX30 Cable Modem/Router. Installed Nighthwak app, got the unit registered, activated and setup. Reconnected all my W...
Dec 28, 2021Guru - Experienced User
Try logging into the modems web page to make channel changes and configurations.
If you locally connected you should have two options to connect to the modem using the NightHawk app, Cloud icon or Locally. Try changing from the Cloud icon access to Locally connected with in the app.
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Thank you.
