denisebur
Feb 23, 2023Follower
Cax30 network is gone
I have the same exact issue. Please let me know if anything works. The network is gone so I cant do any of the suggestions. I am going nuts over this. I have tried 50 different things, I have an open ticket....ARGH!!!!
1 Reply
Supposedly you can try tftp to reload the older firmware to it. You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpawIf that doesn't work, about all you can do is RMA it.
