awdaw221fadw
Nov 18, 2023Aspirant
CAX30 Nighthawk packet loss on a consistent time cycle
CAX30 Nighthawk combination modem/router plugged into COAX cable from wall. 1GB/s download package. A7000 Netgear Wifi Dongle plugged into Desktop PC. Every minute or so, on the same time in...
awdaw221fadw
I mean there's no other modems or routers, just the Nighthawk CAX30.
When I go into the interface for controlling the modem, I only see one option, and it is in "router" mode.
It's on Windows 10.
michaelkenward
Nov 18, 2023Guru - Experienced User
That raises the question as to what delvers the Internet. Those "campus" networks can track back to a router somewhere in the basement. This is not the sort of scenario that these domestic modem/routers are designed for.
Cable modem/routers don't have a "router only" option (no WAN input). They can offer a "modem only" option, for use with a different router, but that's a red herring in this case.
It's on Windows 10.
Windows 10 isn't a lot different from Windows 11 on this front. Did you check the USB settings? And the drivers?
