SimonSaba
Jan 14, 2024Guide
CAX30 No Connected Devices
I have a CAX30 with firmware 2.2.1.12. Whether I log into the router with a web browser (Chrome MacOS Ventura) or with the Nighthawk App (iOS 17) both show No Devices Connected. Also tried Safari wit...
- Jan 16, 2024
Completed the reset and did the reconfiguration manually. I now see all my devices. Thanks for your help.
Jan 15, 2024Guru - Experienced User
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
SimonSaba
Jan 16, 2024Guide
Thanks. I'll try that when I have time to bring the router down, back up the settings, and reset.
- FURRYe38Jan 16, 2024Guru - Experienced User
đ
- SimonSabaJan 16, 2024Guide
To be on the safe side, I'm screenshotting all of the screens where I've made changes. How reliable is the backup .cfg file? I'm thinking to manually reconfigure because if there's something that causing the problem and gets transferred to the .cfg file, I'm back where I started.
If you have some doubts to the config, then ya, setup from scratch first after the FR. However, I'd take a backup to file first off anyways for safe keeping. FR, then setup from scratch and then config for you needs then test. If all is good, save off and new back up at this point.
