Chakodaddy
Aug 07, 2021Follower
CAX30 not able to obtain ip address on some devices or not able to access certain websites
Hi, just purchased the nighthawk CAX30 cable modem/router, setup the wireless, and then upgrade my service with Xfinity to a higher speed. (The purpose of buying this new gateway) Everything seems f...
selniss
Dec 07, 2021Aspirant
I was having this issue, in particular, with my work laptop. For some reason, CAX30 was not assigning an IP to my laptop. After playing with a few settings, I found a solution that works (so far). Under Basic > Wireless > Check "Enable Smartconnect" and save. I will update if it stops working.
Dec 07, 2021Guru - Experienced User
Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
Please start a new thread there and we'll help you out.
Thank you.
