Paulg9879
Feb 07, 2023Follower
Cax30 nothing working
My CAX30 doesn’t have any available Wi-Fi connections and Ethernet ports don’t light up when connected to tv or desktop. Modem is locked up normally and wifi toggle is lit. ISP can see it and reboot i...
Feb 07, 2023Guru - Experienced User
Try a factory reset of the Reset button pressed for 15 seconds then release with the ISP coax line disconnected from the modem?
If all else fails, please make contact with NG support.
https://my.netgear.com/support/contact.aspx
https://www.netgear.com/about/contact-us/
