davkim
Dec 08, 2021Aspirant
CAX30 OFDM impairment, Channel disabled by modem
Hi, I bought a new modem CAX30 (modem +wifi combo, AX2700, DOCSIS 3.1) to use for my RCN 1gig plan. however it is only showing 30 mbps... RCN is showing "The modem is operating in Partial...
Dec 08, 2021Guru - Experienced User
Just curious, do you have the prior ISP modem by chance or where you using a ISP provided modem?
davkim
When i moved to this place no.
so i was using the first BYOD modem from Arris, it was fine but it droped to 30 mbps.
i got a new one cax30 and it still shows 30 mbps.
they brought their own to test once and it looked fine.
that was the only time that they tried their modem.
- FURRYe38Dec 08, 2021Guru - Experienced User
Look fine but was it online long enough to notice the drop?
Seems like if you experiecned this with an Arris modem and now a NG modem, this would be an ISP issue.
You might go back to the ISP and ask them to use there modem unit for say a month or so. See if the problem appears on there device.
- mateo3Dec 17, 2021Aspirant
I've been having the exact same issue for months. I have a Netgear CM1100. Already tried replacing the modem as well. I previously had an older generation Netgear modem. The speed randomly drops to 30 mbps. Please let me know if you find a solution. I've been going crazy trying to figure out what the issue is... Seems like it's a problem with the ISP. I have RCN.
- FURRYe38Dec 17, 2021Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
- davkimDec 23, 2021Aspirant
it seems like RCN is not properly functioning with netgear.
I tried two netgear modem and they both have same problem.
I bought arris one and now it is working and giving me a 1gig speed.
it is just RCN program not working with Netgear products.
- FURRYe38Dec 23, 2021Guru - Experienced User
Any progress on this?
