sryan's avatar
sryan
CAX30 onboard VPN
Has anybody used the onboard VPN on a CAX30 router?
I have been trying for days to get it to function. I have successfully gotten the DDNS
entry to work and can successfully ping the hostname.
I have downloaded the various configuration files and had to integrate the files into the single
.ovpn file required for the current OpenVPN client connect software.
I have tried OpenVPN clients on both my iphone and my macpro with no success.
Both clients timeout.
I don't see anywhere in the CAX interface that reports VPN status.
I have enabled VPN log messages on the CAX30 and see no log messages or event log entries
related to VPN service being active or started or attempts to connect. I do see the DDNS being
successfully updated at startup.
Given the flaky state of the CAX30 firmware, I am looking for confirmation from ANYBODY who has
actually gotten the onboard VPN to work on this device with any client.
Thanks in advance,
sryan
  • Finally got this to work ising the following
    client.ovpn file:
    client
    remote (your hostname here) 12973
    dev tun
    proto udp
    resolv-retry infinite
    nobind
    persist-key
    persist-tun
    <CA>
    (laste ca.crt contents here)
    </CA>
    <CERT>
    (paste client.crt contents here)
    </CERT>
    <KEY>
    (paste client.key contents here)
    </KEY>
    key-direction 1
    <TLS-AUTH>
    (paste ta.key contents here)
    </TLS-AUTH>
    remote-cert-tls server
    cipher AES-256-CBC
    verb 5
    mute 5
    comp-lzo
    fast-io
    route-delay 2
    route-method exe
  • Currently running  V2.1.3.10 firmware (with traffic meter disabled, not on Comcast)
    • sryan's avatar
      sryan
      I'm reposting this in the Cablemodems message board. Sorry for posting it here.
      • Kitsap's avatar
        Kitsap
        Master
        Just a reminder, you cannot test a client device that is connected to the same network where the server (router) is connected.  On a mobile device, you have to turn off Wi-Fi and connect to the internet through cell data.
        I am a Windows/Android type and use the operating system specific OpenVPN applications.  You do not have to manipulate either configuration set to install/import for these operating systems.  Downloaded from the router in a zip file, the Windows configuration set is four files and the Android is one file.
