sryan
Mar 24, 2023Aspirant
CAX30 onboard VPN
Has anybody used the onboard VPN on a CAX30 router? I have been trying for days to get it to function. I have successfully gotten the DDNS entry to work and can successfully ping the hostname. ...
- Mar 28, 2023Finally got this to work ising the following
client.ovpn file:
client
remote (your hostname here) 12973
dev tun
proto udp
resolv-retry infinite
nobind
persist-key
persist-tun
<CA>
(laste ca.crt contents here)
</CA>
<CERT>
(paste client.crt contents here)
</CERT>
<KEY>
(paste client.key contents here)
</KEY>
key-direction 1
<TLS-AUTH>
(paste ta.key contents here)
</TLS-AUTH>
remote-cert-tls server
cipher AES-256-CBC
verb 5
mute 5
comp-lzo
fast-io
route-delay 2
route-method exe
sryan
Mar 28, 2023Aspirant
client.ovpn file:
client
dev tun
proto udp
nobind
persist-key
persist-tun
<CA>
</CA>
<CERT>
</CERT>
<KEY>
</KEY>
key-direction 1
<TLS-AUTH>
</TLS-AUTH>
cipher AES-256-CBC
verb 5
mute 5
comp-lzo
fast-io
route-delay 2
route-method exe
client.ovpn file:
client
dev tun
proto udp
nobind
persist-key
persist-tun
<CA>
</CA>
<CERT>
</CERT>
<KEY>
</KEY>
key-direction 1
<TLS-AUTH>
</TLS-AUTH>
cipher AES-256-CBC
verb 5
mute 5
comp-lzo
fast-io
route-delay 2
route-method exe
Kitsap
Mar 28, 2023Master
Outstanding. Thank you for sharing the details.
Recommend you mark this as resolved so others can benefit.
