WitchyGirl
Sep 01, 2024Aspirant
Cax30 Poor cable connection status downstream
Can anyone help me find what the issue is here? Brand new modem/router combo Nighthawk and comcast is no help. I have tried different coaxial cables along with cat6 cords. I switched out the coax...
Sep 01, 2024Guru - Experienced User
Power levels are way too low:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Please post a copy and paste of the modems event log page.
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
Lots of correctables and uncorrectables that should be zeros.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
- WitchyGirlSep 01, 2024Aspirant
2024-09-01 18:39:45 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:39:24 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:39:21 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:36:20 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:36:18 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:36:13 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:35:35 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:35:25 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:35:05 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:34:57 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:34:29 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:34:25 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:34:09 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 20 25 34 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:34:07 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:34:04 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 26 34 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:34:02 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 20 25 34 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:53 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 26 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:42 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 20 25 34 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:40 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 34 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:37 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 26 34 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:37 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:34 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 26 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:33 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 20 25 34 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:33 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:29 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:23 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:15 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:08 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:33:07 Notice (6) CM-STATUS message sent. Event Type Code: 5; Chan ID: 20 25 34 35; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:31:29 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 34 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:31:26 Notice (6) CM-STATUS message sent. Event Type Code: 2; Chan ID: 26 34 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:31:07 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:31:04 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:31:03 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:30:53 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:30:28 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:30:18 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 34 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:30:07 Warning (5) MDD message timeout;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:29:56 Notice (6) CM-STATUS message sent. Event Type Code: 4; Chan ID: 34; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; 2024-09-01 18:29:49 Notice (6) CM-STATUS message sent. Event Type Code: 1; Chan ID: 25 26 35 39; DSID: N/A; MAC Addr: N/A; OFDM/OFDMA Profile ID: N/A.;CM-MAC=54:07:7d:43:cf:6b;CMTS-MAC=00:01:5c:6a:7e:7d;CM-QOS=1.1;CM-VER=3.1; - WitchyGirlSep 01, 2024Aspirant
Is there any way to change the power? I update the starting frequency and reboot the modem but it always reverts back to 657000000.
- FURRYe38Sep 02, 2024Guru - Experienced User
You'll need to contact the ISP. They need to raise the power.
