dannydiggz
Feb 07, 2025Aspirant
CAX30 Poor Downstream Connection / Partial help
I've had this CAX30 router/modem for about 10-11months. Pro installed by Cox (1gig) I had issues with stability in the past, but it seemed fine for months and now all of a suden back to stability...
- Feb 08, 2025
Just took a second look at your latest cable data. It appears Cox has enabled mid-split in your area. I can see your OFDM channel 2 is running at 918 MHz and the power level is way below specification. There is a good chance Cox did that in the past year.
Whether you only use one connection or not, there could be a splitter in your coax connection. Many old splitters are rated for 5-860 MHz and cause a significant signal loss above that frequency range. The splitter needs to be replaced.
Kitsap
Feb 07, 2025Master
Most of the power levels on your downstream bonded channels are way out of specification (low). For reference look at the first few sentences here:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
Either the coax itself, the connectors, or a splitter between your CAX30 and the ISP have major issues.
Usually this is a situation for the ISP to resolve.
dannydiggz
Feb 08, 2025Aspirant
Thanks for this insight. This morning the speed seems to be up again, speedtest getting 850-950 down with wired connection.
Could you humor me, and let me know what may cause it to be the way it was with the previous data I gave you... but then the next morning seem to be working properly?
This is the data given currently with the downstreaming hitting 850-950.
Thanks again for the input!
Cable Diagnostic
Startup Procedure
CM status: OPERATIONAL
DownstreamChannel: 807000000Hz Locked
ConnectivityState: OK operational(12),
BootState: OK Operational
Security: Enabled
IPProvisioningMode: 12 IPv4Only
Downstream Bonded Channels
Channel LockedStatus Modulation Channel ID Frequency Power SNR Correctables Uncorrectables
1 Locked 256 QAM 37 807000000 Hz -11.8 dBmV 36.5 dB 174684 189
2 Locked 256 QAM 1 117000000 Hz -4.1 dBmV 41.1 dB 152447 203287
3 Locked 256 QAM 2 123000000 Hz -3.5 dBmV 41.8 dB 67375 181638
4 Locked 256 QAM 3 129000000 Hz -2.6 dBmV 42.8 dB 74227 152875
5 Locked 256 QAM 4 135000000 Hz -2.3 dBmV 43.3 dB 99376 206054
6 Locked 256 QAM 5 141000000 Hz -2.8 dBmV 43.4 dB 147953 240175
7 Locked 256 QAM 6 147000000 Hz -3.5 dBmV 43.1 dB 116880 121932
8 Locked 256 QAM 7 153000000 Hz -3.5 dBmV 43.3 dB 172647 234799
9 Locked 256 QAM 21 237000000 Hz -3.5 dBmV 43.9 dB 7741 6547
10 Locked 256 QAM 25 735000000 Hz -9.4 dBmV 38.9 dB 358 711
11 Locked 256 QAM 26 741000000 Hz -9.2 dBmV 39.1 dB 370 422
12 Locked 256 QAM 27 747000000 Hz -9.0 dBmV 39.2 dB 345 376
13 Locked 256 QAM 28 753000000 Hz -10.0 dBmV 38.4 dB 439 335
14 Locked 256 QAM 29 759000000 Hz -10.7 dBmV 37.7 dB 403 490
15 Locked 256 QAM 30 765000000 Hz -10.5 dBmV 37.8 dB 344 629
16 Locked 256 QAM 31 771000000 Hz -11.3 dBmV 36.9 dB 426 904
17 Locked 256 QAM 32 777000000 Hz -12.9 dBmV 35.4 dB 728 1034
18 Locked 256 QAM 33 783000000 Hz -13.2 dBmV 35.3 dB 9040 1317
19 Locked 256 QAM 34 789000000 Hz -12.3 dBmV 36.2 dB 10764 1223
20 Locked 256 QAM 35 795000000 Hz -12.5 dBmV 35.9 dB 57216 851
21 Locked 256 QAM 36 801000000 Hz -12.1 dBmV 36.3 dB 391670 358
22 Locked 256 QAM 38 813000000 Hz -11.6 dBmV 36.7 dB 445165 221
23 Locked 256 QAM 39 819000000 Hz -11.5 dBmV 36.7 dB 3029465 4117
24 Locked 256 QAM 40 825000000 Hz -11.3 dBmV 36.9 dB 5417430 27326
25 Locked 256 QAM 41 831000000 Hz -12.3 dBmV 35.6 dB 4822947 2888861
26 Locked 256 QAM 42 837000000 Hz -13.9 dBmV 34.4 dB 2972506 607205
27 Locked 256 QAM 43 843000000 Hz -13.8 dBmV 34.5 dB 9907784 1932283
28 Locked 256 QAM 44 849000000 Hz -15.7 dBmV 32.6 dB 15260348 4551535
29 Locked 256 QAM 45 855000000 Hz -14.9 dBmV 33.5 dB 17719429 5325461
30 Locked 256 QAM 46 861000000 Hz -14.5 dBmV 33.9 dB 1189302 82194
31 Locked 256 QAM 47 867000000 Hz -14.9 dBmV 33.5 dB 15375984 4417840
32 Locked 256 QAM 48 873000000 Hz -14.5 dBmV 33.8 dB 690591 69845
Upstream Bonded Channels
Channel LockedStatus ChannelType Channel ID SymbolRate Frequency Power
1 Locked ATDMA 1 5120 Ksym/sec 17600000 Hz 48.5 dBmV
2 Locked ATDMA 2 5120 Ksym/sec 24000000 Hz 47.8 dBmV
3 Locked ATDMA 3 5120 Ksym/sec 30400000 Hz 46.5 dBmV
4 Locked ATDMA 4 5120 Ksym/sec 36800000 Hz 46.0 dBmV
5 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV
6 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV
7 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV
8 Not Locked Unknown 0 0 Ksym/sec 0 Hz 0 dBmV
Downstream OFDM Channels
Channel Channel ID Frequency Power SNR/MER ActiveSubcarrier Correctable Uncorrectable
1 159 300000000 Hz -3.0 dBmV 43.7 dB 296 ~ 7895 187387696 1
2 160 918000000 Hz -15.6 dBmV 31.9 dB 2216 ~ 5975 187387696 1
Upstream OFDMA Channels
Channel UpstreamMuted RangingStatus Subc Zero Freq ActiveSubcarrier SymbolsPerFrame Power
2 False Success 36.8 MHz 148 ~ 1907 12 41 dBmV
2 n/a Other 0 MHz 0 ~ 0 0 0 dBmV
