DonaldD
Aug 16, 2022Tutor
CAX30 Port Forwarding Issues with NOIP
Just installed a CAX30 Modem/Router device to replace separate Motorola SM7420 and Netgear WNDR3700v4 on a Windows 10 Pro machine. I changed my RDP port for security purposes. I am a regular RDP use...
- Aug 25, 2022
Update:
After changing the Remote Desktop Protocol on my remote PC, I discovered that the new port number must be also added to the NO-IP PC/Computer entry in Remote Desktop Client.
After adding the new port number to my NO-IP hostname , i.e., "[name].mynetgear.com:[port]" and entering it the "PC/Computer" field in the Remote Desktop Client, the connection was successful.
DonaldD
Aug 25, 2022Tutor
Update:
- michaelkenwardAug 25, 2022Guru - Experienced User
Good one. Needs to go into the collective memory.
Nice bit of research.
