ajman404
Aug 08, 2023Tutor
CAX30 Port forwarding rules disappear as soon as I enter them
CAX30 Router firmware version 1.4.12.2. When I go to port foward and hit save, it does not actually save the setting, and upon refresh the rule is gone. I also have that rule that port 0 is being for...
Aug 09, 2023Guru - Experienced User
What browser are you using? Happening with different browsers?
Be sure to clear out all browser caches before entering the modems web page.
How are you factory resetting the modem?
ajman404
Aug 09, 2023Tutor
Tried with Chrome and Edge. Caches cleared, still no dice. Factory resetting by holding the reset button on the back of the router for 10 seconds until it power cycles.
