ajman404
Aug 09, 2023Tutor
CAX30 Port forwarding rules disappear as soon as I enter them
CAX30 Router firmware version 1.4.12.2. When I go to port foward and hit save, it does not actually save the setting, and upon refresh the rule is gone. I also have that rule that port 0 is being for...
Aug 09, 2023Guru - Experienced User
Which browser did you use to load the FW file? MS Edge or FF is recommended.
ajman404
Aug 09, 2023Tutor
Chrome. However, the firmware took just fine and is running as intended, showing updated firmware and working just fine. The only issue I have here is setting the settings for port forwarding.
- FURRYe38Aug 09, 2023Guru - Experienced User
Could you do a manual re-load of the FW file to the CAX30 using MS-Edge or FF, then once the modem is back to ready, factory reset the modem and setup from scratch using this process:
https://kb.netgear.com/24233/How-do-I-erase-the-configuration-settings-on-my-Nighthawk-router
Once you get it setup, clear out all browser caches, then try a PF configuration. Be sure to disable uPnP before setting up a PF configuration.
- ajman404Aug 09, 2023Tutor
Still no dice.
How long have you had this modem for?
I'm thinking need to open up a support ticket and get this to NG:
https://my.netgear.com/support/contact.aspx
