Frank007p
Dec 11, 2022Aspirant
Cax30 port forwarding settings disappear
I add a custom port forwarding in my cax30 and apply. It looks like it takes but when I toggle back and forth in the menus, the custom port I just added disappear. I even tried the built in port setti...
- Dec 11, 2022
Problem solved with help from Netgear Agent. She advised that I do a reset on the router/modem and it worked. I'm able to do port forwarding.
Frank007p
Dec 11, 2022Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
