fmanzeta
Nov 18, 2022Aspirant
CAX30 Router Traffic Meter Checkboxes Not Staying Checked
I own a CAX30 Nighthawk. Currently on the most recent version, v1.4.10.10 Every time I want to enable Traffic Meter (I've had to have it disabled for the past 6 months because this is still happenin...
Nov 19, 2022Guru - Experienced User
Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch.
fmanzeta
Dec 01, 2022Aspirant
Yeah, I just did a complete, from-scratch, reset of the modem router, as you've outlined. I tried to enable the setting again, and it's still doing it. In addition, I updated the firmware as well.
- FURRYe38Dec 02, 2022Guru - Experienced User
Does this also happen in a different browser and or a different PC as well?
- fmanzetaDec 02, 2022Aspirant
I tried using Edge and Firefox but it hasn't worked. I also tried using a different Windows PC and also a Mac. Yet even then, the settings still stay checked.
- FURRYe38Dec 03, 2022Guru - Experienced User
And you did update FW as well?
Only other idea would be a 30-30-30 reset to see if this kicks out something.
Otherwise, I would reach out to NG support and ask for help and information in this. See if a RMA is an option for you.
