y0ungdhill0n's avatar
May 02, 2022
CAX30 setup with Aruba Networks AP's
Hello,
I've recently bought a Nighthawk cax30, setup was easy internet was up and running, however i have 2 aruba networks access points in the house (1 in the kitchen/Living area, and other in the bedroom hallway). Access points are powered from the cax30 to a gigabit poe switch, they show up in nighthawks app settings as "attached devices" but under Gateway status" 2.4ghz and 5ghz have red dots next to them. Do i need to change something in the aruba access point settings as well? Any help is appreciated.
See attached screenshot for clarity,
Thanks!
  • FURRYe38's avatar
    Does the CAX30 report wifi working with out the two APs?
    The two additional APs would need to be using different SSID names and different far appart channels from what the CAX30 uses to avoid any interferences and wifi problems between these units.
    How big is your home?
    • y0ungdhill0n's avatar
      y0ungdhill0n
      Tutor
      Thanks for the reply! Yes the wifi works without the APs, house is about 4000sqft, the CAX30 is in the garage because the coax connection comes into there and the APs are inside the house. Would i have to channels and SSID in the Aruba settings or the CAX30 settings?
      • plemans's avatar
        did you shut off the wifi on the CAX? usually the red light indicates the wifi is disabled. you can push and hold the wifi on/off button
