Shyam723
Jul 18, 2022Aspirant
CAX30 Slow and unstable speed
My CAX30 has low and unstable internet. My 5GHz which is supposed to go up to 800 mbps caps at 351 and fluctuates from 120-351. My 2.4GHz fluctuates from 81 to 220 mbps on my laptop. On startup, th...
Jul 18, 2022Guru - Experienced User
What wireless device do you have connected?
Are your wireless devices supporting of AX modes?
Some devices don't support 866, 1300 or higher connection rates so you may not see anything near 800mpbs on wireless.
Connect a wired PC to the modem and speed test with Ooklas installable speed test app. You should see near 800Mbps speeds here.
- Shyam723Jul 18, 2022Aspirant
Firmware Version V1.4.10.8
There are 9 wireless devices connected to the router. Most of them are my families and are connected to the 2.4GHz, as per my knowledge, there are 2 laptops and 1 phone connected to the 5GHz one.
I am not sure. The laptop in question is a Dell Latitude E7240, so its on the older side. The other laptop, which is a Mac, that is connected also experiences slow speeds at times, so I don't think its a problem with my laptop itself.
On ookla, I'm getting about 150 mbps.
Forgot to mention, with wired its about 600 mbps, but wired connection isn't viable for me.
- FURRYe38Jul 18, 2022Guru - Experienced User
You'll need to check with the wireless devices Mfr to see what connection rates and wireless modes that are supported on those devices.
Most AC supporting devices top out at around 300Mpbs on 5Ghz AC.
By wired, I mean I connected my laptop directly to the router with a cable.
