JohnnieWalker22
Aug 25, 2021Guide
CAX30 Slow Internet Speeds
Hello all Need some help please. I recently decided to get my own modem instead of renting one out from Xfinity. I got tired of their XB7. I bought a brand new Nighthawk CAX30 (AX6 AX2700) about ...
michaelkenward
Aug 26, 2021Guru - Experienced User
JohnnieWalker22 wrote:
I wanted to know if there was any other settings I am missing before I Hard Reset it? If I hard reset and is the same result, is there anything else I can try? I wanted to try as much as possible before I spend hours on the phone with Netgear..
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Cable Modems & Routers
Modems are a bit specialist and, apart from plemans , there may not be that many cable modem experts hanging around in this section.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
