JohnnieWalker22
Aug 25, 2021Guide
CAX30 Slow Internet Speeds
Hello all Need some help please. I recently decided to get my own modem instead of renting one out from Xfinity. I got tired of their XB7. I bought a brand new Nighthawk CAX30 (AX6 AX2700) about ...
ashari50
Oct 31, 2021Tutor
Thanks for the reply & suggestion. I will start a new thread under the forum you pointed out.
BTW, yes, the model no is CAX30 (Netgear Nighthwak AX6 AX2700) - sorry for missing the full details.
Thanks,
Harry
michaelkenward
Oct 31, 2021Guru - Experienced User
No problem. Netgear labels these things in baffling ways.
As the main point of your question seems to be modem related, you may get more knowledgeable advice over there. This place is for the router brigade. Even then it isn't the best place to ask about "RAX" routers. They have their own bolthole:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
I warned you that it is complicated.
