Washautumnstar
Aug 02, 2021Aspirant
CAX30 Slow Wifi
I am at my wits end and hoping someone has some answers. I have been having issues with slow internet speeds. When my package was for 400mbps, I was getting 250, I thought it wasn't too bad. Recent...
Washautumnstar
I have tested with multiple devices on multiple speed test sites: desktop/2 laptops/android smartphone. Ookla, Xfinity, and Netgear speed sites. All of these were on my 5G network
I also thought that the cards I had should have at least gotten to 400. So I got the new adapter, which is an Edimax EW-7833UAC AC1750 which as mentioned, says it should be able to get speeds up to 1300. But I'm still stuck around 250
Aug 02, 2021Guru - Experienced User
Washautumnstar wrote:
I have tested with multiple devices on multiple speed test sites: desktop/2 laptops/android smartphone. Ookla, Xfinity, and Netgear speed sites. All of these were on my 5G network< is this the 5G wireless on the CAX or cell service?
I also thought that the cards I had should have at least gotten to 400. So I got the new adapter, which is an Edimax EW-7833UAC AC1750 which as mentioned, says it should be able to get speeds up to 1300. Wifi bandwidth will never see 1300Mbps bandwidth download speeds on 5Ghz AC with your adapter.
Its rating is:Data Rate
11a: 6/ 9/ 12/ 24/ 36/ 48/ 54Mbps
11b: 1/ 2/ 5.5/ 11Mbps
11g: 6/ 9/ 12/ 24/ 36/ 48/ 54Mbps
11n (20MHz): MCS0-15 (up to 223Mbps)
11n (40MHz): MCS0-15 (up to 450Mbps)
11ac (80MHz): MCS0-9 (up to 1300Mbps)FYI, These are DATA Connection RATES only. Meaning that its the connection rate seen between the this adapter and host wifi router. This is NOT actual bandwidth download speeds. This differs from Data Rate. https://kb.netgear.com/19668/Link-Rate-and-Transfer-Speed
I would agree though that if the adapter is connected at 1300Mpbs, it should be seeing around 500Mpbs on 5Ghz with the CAX.
Is Smart Connect enabled on the CAX?
What FW is loaded on the CAX?
And be sure the USB adapter is connected to a USB 3.0 port on the PC?
