USER35
Feb 27, 2023Tutor
CAX30 Xfinity
Were you lucky and not have your eth ports get disabled? I'm stuck trying to work around the ethernet being disabled. Unable to use the NH app or have wifi broadcasting. No idea how to access the rou...
Feb 27, 2023Guru - Experienced User
Try the TFTP method to see if you can get v1.4x FW loaded on it:
Let us know if the TFTP works for you or not.
