ju66er
Jun 16, 2022Aspirant
CAX30S stopped responding after reboot
My Nighthawk CAX30 was getting slow speeds yesterday so I unplugged and rebooted it. After that I couldn't connect to it at all. Tried the app but the device wasn't found. I tried various ethernet ca...
Jun 16, 2022Guru - Experienced User
Please post a copy and paste of the modems connection status page.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router?article=24311
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
Factory reset the modem and setup from scratch with a wired PC and web browser...
ju66er
All of the above have been done. I was on the phone with my ISP multiple times trying to troubleshoot this device. Once again, I cannot access the unit so I can't post a status page of any sort. The connection works fine using my older Netgear modem/router, so it's not my ISP. Factory reset does nothing. I tried resetting, unplugging it for up to 10 minutes, used different ethernet cables. On my browser i have tried routerlogin.com, routerlogin.net, 192.168.0.1, 192.168.1.1 but I cannot connect the the router interface at all. I have owned many Netgear routers so I'm familiar with troubleshooting and so far nothing I know is working.
- FURRYe38Jun 16, 2022Guru - Experienced User
You'll need to Contact NG support and see what your options are:
https://my.netgear.com/support/contact.aspx
Ask about an RMA.
Good Luck.
