kkola
Dec 07, 2023Aspirant
CAX30s Xfinity 1G speed issues
I recently within the past month purchased a CAX30. At the time I was running Xfinitys 800 speed. Through ethernet I was getting 920ish mbps and everything was good. I recently upgraded to 1G speeds ...
kkola
This is on a cat 8 ethernet wired. Firmware version 1.4.12.2. I had upgraded firmware to the latest when i first got the CAX30 but the speeds were terrible so I came back down to 1.4.12.2 and hadn't had any issues until today
| Time | Priority | Description |
| 2023-12-07 18:14:56 | Critical (3) | Started Unicast Maintenance Ranging - No Response received - T3 time-out; |
| 2023-12-07 17:43:57 | Error (4) | SW upgrade Failed before download -TFTP Max Retry Exceeded |
| 2023-12-07 17:43:27 | Notice (6) | SW Download INIT - Via Config file d11_m_cax30_extremepro_c01.cm |
| 2023-12-07 17:43:16 | Notice (6) | DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: |
| 1970-01-01 00:00:41 | Notice (6) | Honoring MDD; IP provisioning mode = IPv6 |
| 1970-01-01 00:00:35 | Critical (3) | No Ranging Response received - T3 time-out;CM- |
| 1970-01-01 00:00:29 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing; |
| 2023-12-07 17:41:28 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| 1970-01-01 00:00:30 | Critical (3) | No Ranging Response received - T3 time-out |
| 1970-01-01 00:00:24 | Critical (3) | SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing; |
| 1970-01-01 00:00:29 | Critical (3) | No Ranging Response received - T3 time-out;CM- |
| 2023-12-07 16:23:15 | Critical (3) | Resetting the cable modem due to docsDevResetNow |
| Frequency start Value | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| This field below allows you to modify the frequency the cable modem start with its scan during initialization and registration. Enter the new start frequency and restart the cable modem for it to take effect. | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| Starting Frequency | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Startup Procedure</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Downstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream Bonded Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Downstream OFDM Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream OFDMA Channels</tabindex=-1> | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
Dec 07, 2023Guru - Experienced User
Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Power is on the low side but with specs:
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
There's lots of uncorrecables and correctables on one channel that should be zeros like the other channels.
I'd re-update FW back to suggested. Then have the ISP take a look at what has been put forth here.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
