cmerc
Feb 08, 2022Tutor
CAX80 – Issues with Downstream
Hi, I recently purchased a CAX80 from Netgear (Oct 2021). It's been great. I bought it due to some research and customer reviews on several consumer retail sites. Over the last 3-4 weeks, our int...
- Feb 09, 2022
Yeah they'll need to check the line
cmerc
Feb 08, 2022Tutor
I have the device plugged in right where the coax comes in. I'm in a condo complex and the cable comes in from the closet ceiling, so probably not direct from outside. I may need to have the ISP tech come out to figure out all of the wiring. Thanks for the suggestions.
cmerc
Feb 09, 2022Tutor
Here's an update. I plugged in my previous modem (MB7621) and received similar numbers — the power is far too low. I'm having my ISP tech come out tomorrow morning to help troubleshoot this. My assumption is this is an issue with the cable that comes into the house. I've am told I'm provisioned at 500mbps, which is what I'm paying for. Currently getting about 30-35mbps.
- plemansFeb 09, 2022Guru - Experienced User
- cmercFeb 10, 2022Tutor
Yup! All set. CAX80 is running smoothly – back up to 490-500 speeds. Squirrel got to some of the cables outside and water got in, distupting the service. Thanks again for the quick responses.
- plemansFeb 10, 2022Guru - Experienced User
glad it fixed it!
if you mark it solved, it might help the next person
