GuidonCreative
Jan 13, 2024Tutor
CAX80 - Any update on 5Ghz Upload issue?
So reading through a lot of posts here, I finally did what was suggested and changed from 5Ghz to 2.4Ghz and to my utter surprise, all devices in my house that FAILED trying to upload to various site...
Jan 13, 2024Guru - Experienced User
What FW version is currently loaded?
What devices are connected on 5Ghz?
Is Smart Connect enabled or disabled? Does this happen if SC is enabled?
What channel configuration is on the modem?
- GuidonCreativeJan 14, 2024Tutor
Hardware Version 1.01 Firmware Version V2.1.5.2 Cable Firmware Version V1.02.08 Windows 11 laptops (upload issue on 5Ghz), windows 11 pro desktop (upload issue on 5Ghz), MAC desktop (upload issue on 5Ghz), galaxy s23 ultras (upload issues on 5Ghz).
Smart connect is NOT enabled
2.4 - Channel select is auto, current is 4
5Ghz - Channel is set to 36
When i selected smart connect, it says it's going to overwrite my settings with the 2.4G settings - why would i want to change from up to 4800Mbps down to 1200Mbps? That makes no sense - I would have just bought a cheaper modem.
- FURRYe38Jan 14, 2024Guru - Experienced User
Lets try it enabled
Lets try channel 1, 6 or 11, not channel 4.
You mis understand that. 2.4Ghz max connection rate for any wifi device connecting to it is 1200Mpbs.
5Ghz, you can have any devices that support it, connect at 4800Mpbs. Smart Connect just puts both frequencies into on SSID named broadcast is all. Smart connect enabled or disabled.
https://www.netgear.com/images//datasheet/networking/CableModems/CAX80.pdf
Also what are the configuration settings under Advanced/Advanced Settings/Advanced Wireless?
Has a factory reset and setup from scratch been performed since FW was updated?
Lets try it enabled - didn't fix it for others when they tried it looks like - i appreciate the suggestion but i don't want to duplicate what hasn't worked elsewhere in these threads.
Lets try channel 1, 6 or 11, not channel 4. - 2.4Ghz works perfectly fine - no need to change that channel It's the only frequency it will upload properly on. It's the 5Ghz freq that is the problem.
5Ghz, you can have any devices that support it, connect at 4800Mpbs. Smart Connect just puts both frequencies into on SSID named broadcast is all. Smart connect enabled or disabled. OK
Wireless Advanced Settings (2.4GHz b/g/n/ax)
Fragmentation Length (256-2346):
2346
CTS/RTS Threshold (1-2347):
2347
Preamble ModeLong Preamble
The wireless signal is scheduled to turn off during the following time period:
Period Start End Recurrence Pattern
Add a new period Edit Delete
Wireless Advanced Settings (5GHz a/n/ac/ax)
2346
2347
WPS Settings
Router's PIN:Has a factory reset and setup from scratch been performed since FW was updated? Everything else works on the device. Not factory resetting when i can just fix NetGears issue by changing to 2.4Ghz when i need to upload, that way I don't have to mess with anything else on my network. I have too many static IP's and configs for specific devices on my network to go through that process unless the router burns to the ground and forces me to.
