PatTestsys
Dec 16, 2021Aspirant
CAX80 - backup with 5g
Anyone have any suggestions on how to configure a backup mobile device with Nighthawk AX6000 DOCSIS 3.1 WiFi 6 Cable Modem Router (CAX80)? My Comcast provider is unreliable, and I have no other broa...
Dec 16, 2021Guru - Experienced User
You mean like having a backup ISP service?
Is that what you're asking?
If so, that model doesn't support failover or dual wan.
- PatTestsysDec 16, 2021Aspirant
Yes, that is exactly what I am talking about. I think I found a solution with the new Orbi 5G system. I can hook that to my cable modem, and it will failover to 5G when the cable modem fails. Also supports 2 additional gigabyte lan ports, which I need. I currently use an eero mesh with my CAX80 (the CAX80 is great wifi, but doesn't cover my third floor), so this would replace that component. Pricey though.
- FURRYe38Dec 16, 2021Guru - Experienced User
So both CAX80 and Orbi don't support cell signal services. 5G or 5Ghz on NG products means a 5Ghz wifi signal. Not the 5G or 5th Generation cell services. Orbi as a LTE cell service product The LBR20 series.
Well, Netgear is selling one. https://www.netgear.com/home/wifi/mesh/nbk752/. Started shipping in November.
