rearwheelmaniac
Feb 14, 2021Aspirant
CAX80 - Can a software update make it mesh capable.
I just bought this router. it has the latest firmware(2.1.1.4). I simply overlooked the mesh capability part because I figured a modem of this caliber would cover my home. It is a 2 story, <2000 sqft...
Feb 14, 2021Guru - Experienced User
No the CAX80 isn't a mesh router and won't be upgraded to that.
But you could always add mesh extenders like the EAX15/EAX20/EAX80 to it.
Or you could add a mesh system and run it in AP (access point mode)
If your home is only 2000sqft, then the cax80 should just about cover it if its standard construction. If its not, then an extender could help.
- rearwheelmaniacMar 28, 2021Aspirant
Definitely standard construction. Just sad. at paying $429.99 and to have the range so short.
- plemansMar 28, 2021Guru - Experienced User
Have you tried moving it around a little?
Sometimes unexpected things in the walls like hvac/foil lined insulation can cause issues
