PDXCrusier
Sep 14, 2023Tutor
CAX80 - can't upload files through browser except when on VPN
I am having an issue where on certain websites, I can't upload files. This issue is happening across multiple devices (Mac, iOS, and Windows). The issue is happening across multiple browsers, Firef...
- Sep 14, 2023
the .bin file.
Sep 14, 2023Guru - Experienced User
Yes manually applying FW needs a wired PC and web browser. MS Edge or Firefox is recommended.
However other say v2.1.5.2 has same issue. Others posted that they contacted NG support and asked for a beta that was provided to help resolve this. Something you might reach out to NG support first and ask about.
PDXCrusier
Sep 14, 2023Tutor
Thank you for these details. Would you recommend I update to the latest firmware first? My guess is that Netgear are going to recommend that as a next step anyway.
Also, how do I contact support to request a beta firmware? The phone numbers are for business users and every other link I see leads me back to these forums.
Thank you!!
- FURRYe38Sep 14, 2023Guru - Experienced User
- PDXCrusierSep 14, 2023Tutor
OK I am attempting to update the firmware to the latest release version before contacting support.
The installation instructions state that, "The correct firmware file uses an .img or .chk extension.
I found the instructions at this URL: https://www.downloads.netgear.com/files/GDC/CAX80/CAX80_UM_EN.pdf
Then I downloaded the firmware file from this URL:
https://www.netgear.com/support/product/cax80#download
The downloaded file is a .zip file.
When I expand that, there is an .html file and a .rar file.
When I expand the .rar file, there is a .bin file.
There is no .img or .chk in the download package.
What file should I upload to the device itself?!
the .bin file.
