PDXCrusier
Sep 14, 2023Tutor
CAX80 - can't upload files through browser except when on VPN
I am having an issue where on certain websites, I can't upload files. This issue is happening across multiple devices (Mac, iOS, and Windows). The issue is happening across multiple browsers, Firef...
- Sep 14, 2023
the .bin file.
PDXCrusier
Sep 14, 2023Tutor
OK I am attempting to update the firmware to the latest release version before contacting support.
The installation instructions state that, "The correct firmware file uses an .img or .chk extension.
I found the instructions at this URL: https://www.downloads.netgear.com/files/GDC/CAX80/CAX80_UM_EN.pdf
Then I downloaded the firmware file from this URL:
https://www.netgear.com/support/product/cax80#download
The downloaded file is a .zip file.
When I expand that, there is an .html file and a .rar file.
When I expand the .rar file, there is a .bin file.
There is no .img or .chk in the download package.
What file should I upload to the device itself?!
Sep 14, 2023Guru - Experienced User
the .bin file.
- PDXCrusierSep 14, 2023Tutor
THIS WORKED!
Thank you for your quick assistance!
I have been fighting with this issue for weeks and it looks to be resolved now.
I can't thank you enough!
- FURRYe38Sep 14, 2023Guru - Experienced User
Awesome.
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡- PDXCrusierSep 14, 2023Tutor
Done! Thanks!
