steach91
Nov 27, 2021Aspirant
CAX80 - Error submitting a Warranty Claim
My CAX80 has stopped connecting to the internet both via Ethernet and Wifi. Have attempted factory reset, and swapped it out with other devices that connect immediately. Trying to submit a warranty...
steach91
Nov 28, 2021Aspirant
Yes I am aware of that.
I literally said the form is erroring out when I try to submit it. Is there another avenue?
Edit: wait, I have to purchase a support plan to file a warranty claim?
Nov 28, 2021Guru - Experienced User
You should be able to call into support. When you talk to support, they take you through some very basic "does it work" steps. If it does work, then it costs $ to talk to them. But if it does indeed turn out to be a hardware failure, they're supposed to refund it.
