AHU
Nov 21, 2021Follower
CAX80 - Regrate to Purchase it.
I had C6300 and decided to go with piece of junk CAX80 (Paid $459) due to my cable Internet upgrade to 1Gbit. CAX80 worked for 104 Days only and it stop connecting to Internet. Internet provider said...
Nov 22, 2021Guru - Experienced User
Are you able to access 192.168.100.1?
Are you able to ping the router?
One thing to check on is my understanding of the paid support is that if it is a hardware failure requiring RMA that they refund you the service contract. I'd check into that as a hardware failure should be covered under warranty.
