jesmith602
Oct 23, 2022Apprentice
CAX80 + Antronix MRAM1-15-G2
Cox installed an amplifier (https://www.antronix.com/datasheet?id=ds-1187-ar-a02_mram115-g2.pdf) to correct some pixelation and choppiness on the TV side, but wonder if I need to do anything on the CA...
jesmith602
Oct 24, 2022Apprentice
Firmware is 2.1.4.2. The MRAM1 is both a splitter and an amplifier, but there are no other splitters.
Oct 24, 2022Guru - Experienced User
What do you see if you remove this amp/splitter from the line?
