jesmith602
Oct 08, 2020Apprentice
CAX80 + Cox ISP Challenges: recurring disconnects
I purchased my first CAX80 in mid-August--Netgear sent me a replacement a month later when their tech support could not figure out why my Cox ISP connection was dropping multiple times a day. Here ar...
kulkarnipb
Dec 08, 2020Tutor
I am on latest xfinity firmware for CAX80 and having daily 3 to 4 disconnects.
Firmware Version V2.1.1.4 |
Anyone has any luck to solve this ?
Dec 09, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Be sure to power OFF the modem for 1 minute them back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
kulkarnipb wrote:I am on latest xfinity firmware for CAX80 and having daily 3 to 4 disconnects.
