apparsa
Jul 23, 2024Follower
CAX80-100NAS issue
My CAX80-100NAS only shows power light on. The other lights blink for few seconds and then turn off. I checked with Comcast, there are no issues on their side and I rented a modem/router from them an...
Jul 23, 2024Guru - Experienced User
With the CAX80 disconnected from the ISP Coax cable line, perform a 30-30-30 reset on the modem. Use a phone with a timer so you can press and release and each 30 second interval.
After the last 30 second reset button release, connect the modem back to the ISP cable line. Connect one ethernet connected PC to the back of the modem. Give a couple of minutes, can you access the modems web page at 192.168.1.1 at all?
