whitesox05
Jan 31, 2021Aspirant
CAX80-100NAS keeps losing internet access
I bought it the CAX80-100NAS a few days ago and have to restart it daily because it just keeps stopping internet connection. When this happens I can not get both ethernet connection and wifi. I ahve ...
- Jan 31, 2021
who's your isp?
If you log into your debug dashboard (ip address/debug.htm for example 192.168.1.1/debug.htm) is your enable wan packet capture checked? if so, uncheck it. I've found when thats enabled, mine slows down after a period of time and if I reboot the router, it auto-enables for some reason
whitesox05
whitesox05 wrote:I bought it the CAX80-100NAS a few days ago and have to restart it daily because it just keeps stopping internet connection. When this happens I can not get both ethernet connection and wifi. I ahve called my ISP and they say that it shows connection is good on their end. So I'm at a loss. Have any of you run into this situation? Have you been able to fix it? If so, how? Do I just have a faulty device? I don't want to call support because I was there for an hour without response the last time I called.
Thank you it was checked. I unchecked it and hopefully that works. My ISP is RCN
