DayneJake1
Jan 29, 2024Star
CAX80-100NAS with Xfinity wifi texting failing
We have Xifinity internet and Xfinity mobile. The AX6000 was purchased by us and then connected to Xfinity. Starting in December, both my wife and my Samsun Galaxy S21 phones started having issues ...
Jan 29, 2024Guru - Experienced User
The CAX80 gateway modem doesn't or shouldn't be filtering or blocking MMS or text messages. I've not seen this on mine ever.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
DayneJake1
Jan 29, 2024Star
event log and connection diagnostics attached.
