DayneJake1
Jan 29, 2024Star
CAX80-100NAS with Xfinity wifi texting failing
We have Xifinity internet and Xfinity mobile. The AX6000 was purchased by us and then connected to Xfinity. Starting in December, both my wife and my Samsun Galaxy S21 phones started having issues ...
Jan 29, 2024Guru - Experienced User
The CAX80 gateway modem doesn't or shouldn't be filtering or blocking MMS or text messages. I've not seen this on mine ever.
Be sure to disable any MAC Address randomizers on phones and pads while at home:
https://community.netgear.com/t5/Nighthawk-App/NETGEAR-Mobile-Applications-and-Apple-Devices-FAQ/td-p/2220015/jump-to/first-unread-message
Armor, Smart Parental Controls or Circle, Traffic Meter.
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Please post a copy and paste of the modems connection status and event log page.
https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
DayneJake1
Jan 29, 2024Star
Changing phone to not random didn't work.
- FURRYe38Jan 29, 2024Guru - Experienced User
Ok, power levels are ok.
We see correctables and un-correctables that should be zeros here.
A couple of Criticals in the events log. Any Criticals, Errors or Warnings seen in the event logs needs to be reviewed and resolved by the ISP. Indicates a signal issue on the ISP line up to the modem.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, loose connections, bad/old/cheap connectors, or corroded connections. Replace them if you do.
Be sure to power OFF the modem for 1 minute then back ON.
https://community.netgear.com/t5/Cable-Modems-Routers/General-info-and-Troubleshooting-for-Cable-Modems/m-p/1530376#M12853
https://kb.netgear.com/24311/Power-level-guidelines-for-a-NETGEAR-cable-modem-router
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/Try disabling the following and see:
Armor, Smart Parental Controls or Circle, Traffic Meter.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Has a factory reset and setup from scratch been performed yet with a wired PC and web browser?
https://kb.netgear.com/22697/How-do-I-install-my-NETGEAR-router-using-the-router-web-interface
Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router- plemansJan 29, 2024Guru - Experienced User
a lot of those android devices are moving to RCS using google messages. They've got their own issues with some wifi services. It might be worth checking some troubleshooting related to that.
https://support.google.com/messages/thread/182154342/chat-features-not-working-when-on-wifi?hl=en
here's a few just after a brief googling.
