BlazinJon_'s avatar
BlazinJon_
Follower
Mar 15, 2025
CAX80 5Ghz - Upload Issues
Ive seen a few posts on here about the upload issue with the 5ghz band. I'm having the same exact issue and attempted the same fixes. 2.4 band works just fine. Im on the latest firmware 5.1.1.8, reinstalled the latest firmware twice and nothing. Was working fine for over a year. Xfinity recently serviced my area and i believe its connected with that.
1 Reply
  • plemans's avatar
    Did you try a factory reset?
    Its only on upload and only on 5ghz?
    wired is fine?
    And download is fine?
