FlankerN7
Feb 28, 2021Follower
CAX80 All lights are blinking and port lights are solid
My NightHawk Model CAX80 has gone in to a blinking light mode. The top 5 lights are blinking fast and the bottom port lights 1-4 are solid, no blinking. I have tried a hard reset, I have unplugged ...
Feb 28, 2021Guru - Experienced User
So try a reset with out the coax cable connected and just 1 wired PC. Press the reset button for 10 seconds then let go.
If this fails, I would reach out to NG support and ask about what your options are.
mrRandyRankin
Mar 23, 2021Aspirant
Experiencing the same issue today. Working well last night and now not able to connect with all 5 lights flashing/blinking.
Has this be solved?
Has this be solved?
- FURRYe38Mar 23, 2021Guru - Experienced User
Has this be solved? - Luis23verSep 01, 2021AspirantSame issue, did you fixed?
