FlankerN7
Feb 28, 2021Follower
CAX80 All lights are blinking and port lights are solid
My NightHawk Model CAX80 has gone in to a blinking light mode. The top 5 lights are blinking fast and the bottom port lights 1-4 are solid, no blinking. I have tried a hard reset, I have unplugged ...
mrRandyRankin
Mar 23, 2021Aspirant
Experiencing the same issue today. Working well last night and now not able to connect with all 5 lights flashing/blinking.
Has this be solved?
Has this be solved?
Mar 23, 2021Guru - Experienced User
So try a reset with out the coax cable connected and just 1 wired PC. Press the reset button for 10 seconds then let go.
If this fails, I would reach out to NG support and ask about what your options are.
Has this be solved?
