MJ2222
Aug 08, 2023Follower
CAX80 and Bluestream Fiber
Any advice on whether I can use my router modem with Bluestream fiber? My equipment is less than 6 months old. Any recommendation in case unable to use?
Aug 08, 2023Guru - Experienced User
Fiber required ONT hardware. You'll need to contact them to check on there requirements. The CAX80 is for Cable ISP only.
