brsox88
Dec 22, 2020Tutor
CAX80 and Samsung TV Issues
Hi, I am having an issue with my CAX80 modem/router. Ever upgrading to this from my C7000 my Samsung TV’s no longer want to stream well and I can’t get their “TVPlus” to work anymore. All things seem...
brsox88
Dec 22, 2020Tutor
I appreciate the quick response, but most of your questions I already tried and mentioned in my original post. To the other ones:
One TV is 2 feet from the router, the other is directly above it on the second story.
I have nothing else to test if streaming is only an issue with the TV's, but computers and mobile phones all seem fine. TVplus is only for use on Samsung TV's. These issues did not happen with our old c7000 so its seems like some new setting or compatibility issue between this new CAX80 and the TVs.
Default DNS does not help any different, but using google DNS I read in other posts here was suggested.
Dec 22, 2020Guru - Experienced User
I'd ensure the TV firmware is updated. There is new wireless tech in AX systems that maybe incompatible with older FW versions in TVs.
Try disabling AX mode on the modem.
