Toby2006
Jan 03, 2022Guide
CAX80 and Skybell Video Doorbell
I'm having an issue with a Skybell video door bell going off line. Not receiving much help from Skybell. Any ideas if there is a setting in the CAX80 configuration that could be blocking the the do...
Jan 03, 2022Guru - Experienced User
Have you tried changing what channel the wifi is broadcasting on for 2.4gh?
Toby2006
Jan 03, 2022Guide
No I haven't changed it. I believe it's set to Auto.
Some suggestions offered:
Open the following ports in your router:
5683-5684 UDP
5004-5010 UDP
16384 - 32767 UDP
443 UDP,TCP
123 UDP (NTP)
53 TCP,UDP (DNS)
Many routers offer a setting like: Tx Burst, Frame Burst, or Packet Burst. Turn them off.
SIP ALG stands for Application Layer Gateway. Many routers have SIP ALG turned on by default. Look in the "Advanced" settings/WAN setup of your router configuration and disable this setting.
All of the above has me concerned not knowing what they do or if I'm opening the unit to suspicious activity.
