Toby2006
Jan 03, 2022Guide
CAX80 and Skybell Video Doorbell
I'm having an issue with a Skybell video door bell going off line. Not receiving much help from Skybell. Any ideas if there is a setting in the CAX80 configuration that could be blocking the the do...
Toby2006
Jan 04, 2022Guide
No, but I believe it's set to auto. Here is all I can get from Skybell. Open these ports in your router: 5683-5684 UDP 5004-5010 UDP 16384 - 32767 UDP 443 UDP,TCP 123 UDP (NTP) 53 TCP,UDP (DNS) Tx Burst, Frame Burst, or Packet Burst. Turn them off. SIP ALG stands for Application Layer Gateway. Disable this setting. Disable Flood Protection. I'm questioning these suggestions. No idea what they do or if they will open the router to suspicious activity. |
Jan 04, 2022Guru - Experienced User
I would start with changing the 2.4ghz value to a set 1/6/11 versus auto.
You can also disable sip alg.
That's where I'd tart.
- Toby2006Jan 04, 2022Guide
I found SIP ALG and have it disabled.
I'm lost on your reference to "changing the 2.4ghz value to a set 1/6/11 versus auto". Are you referring to Advanced / Wireless Setup / Channel? It's set to Auto and currently on 8. You'll suggesting to set it to either 1, 6, or 11?
