Toby2006
Jan 03, 2022Guide
CAX80 and Skybell Video Doorbell
I'm having an issue with a Skybell video door bell going off line. Not receiving much help from Skybell. Any ideas if there is a setting in the CAX80 configuration that could be blocking the the do...
Toby2006
Jan 04, 2022Guide
I found SIP ALG and have it disabled.
I'm lost on your reference to "changing the 2.4ghz value to a set 1/6/11 versus auto". Are you referring to Advanced / Wireless Setup / Channel? It's set to Auto and currently on 8. You'll suggesting to set it to either 1, 6, or 11?
Jan 04, 2022Guru - Experienced User
yes, try channels 1 6 or 11
