Dohness's avatar
Dohness
CAX80 and slow downloads with Xbox Series X|S
I just picked up a new CAX80 earlier today, this is the first time for my personally to use my own modem with my ISP (Spectrum) in probably 10+ years.   However, after getting everything online and...
  • FURRYe38's avatar
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    Do other devices wired and wireless have good download speeds?
    Does your ISP support native IPv6 protocol? If not, I would disable IPv6 on the modem.
    How far away is the modem from the game consoles?
    Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
    Try and disable AX mode on the Modem as well to test.
    Do you have Armor or SPC enabled?
