sara03
Mar 04, 2023Follower
CAX80 AX6000 Power Adapter Barrel Connector
I received a replacement power adapter for this modem/router and it looks like it doesn't fit due to the center pin of the connector. Is this something I can just bend and break off to get it to work...
Mar 04, 2023Guru - Experienced User
https://www.reddit.com/r/NETGEAR/comments/11hg0n2/cax80_ax6000_power_adapter_barrel_connector/
sara03 wrote:
I received a replacement power adapter for this modem/router and it looks like it doesn't fit due to the center pin of the connector. Is this something I can just bend and break off to get it to work or will I need a different one? Also, does anyone know why every replacement shows a center pin but I have one with a plug that is solid? I think the barrel is 7.4mm x 5.0mm
